1998 Ford Explorer STARTING
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
DA ONE
About 3 weeks ago I had to turn my key 2 or 3 times to get my car to start. At the same time I started having trouble with my transmission moving in reverse. Could the problem be related to one another???
Mar 21, 2009 at 8:42 PM
2CARPRO JACK
  • 11,533 POSTS
Did the engine turn over when it wouldnt start? If so
http://www.2carpros.com/dia/test_fuel_pressure.htm
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
othrewise,Could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
If the shifter goes into R and it doesnt move, probably a trans issue, try a service first
Mar 22, 2009 at 2:07 AM
