1998 Ford Explorer Stalls when put into reverse and at stop
FTYSVN24
  • 1998 FORD EXPLORER
  • 4 CYL
  • 157,000 MILES
My 1998 ford explorer putters and stalls when put into reverse and after it has heated up, will stall when it comes to a complete stop; unless it is shifted into Neutral. Would this be a transmission issue, IAC, Torque Converter or something else?
Friday, August 20th, 2010 AT 9:44 PM
  • 109,752 POSTS
Has the check engine light come on? Also, have you checked for vacuum leaks?
Friday, August 20th, 2010 AT 10:35 PM
FTYSVN24
No, no check engine light. Everything else seems to be fine. Just that issue with the stalling.
Friday, August 20th, 2010 AT 11:03 PM
  • 109,752 POSTS
If you haven't done it yet, check for vacuum leaks, and fuel pressure. Let me know what you find.
Friday, August 20th, 2010 AT 11:05 PM
