1998 Ford Explorer stalling
ROVER571
Engine Performance problem
1998 Ford Explorer V8 All Wheel Drive Automatic
acts like its cutting out and kicking bk on while driving causing vehicle to jerk and stalls out intermittenly while coming to stop. also chugs like getting ready to stall when coming to stop..sorry out of work right now and have nothing to donate but will come bk to site and do so when able. need help to fix vehicle desperatly
Mar 8, 2010 at 12:13 AM
  • 75,988 POSTS
Chugging,bogging,hesitating,lack of acceleration etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 8, 2010 at 12:26 AM
