1998 Ford Explorer squeaky front end
JOEY B
  • 1998 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 144,000 MILES
A squeaky front end as you drive over bumps and only make right turns, I just recently had the shocks done and ball joint check? What could it be?
Monday, January 14th, 2008 AT 1:59 PM
MERLIN2021
  • 17,250 POSTS
Check the upper control arm bushings, some are greasable some arent. Also check the idler arm, they are connected to the drag link, and bolt to the right frame.
Monday, January 14th, 2008 AT 2:19 PM
CHAZ312
  • 8 POSTS
I agree with merlin, but also check the front shocks as they can also cause a squeak when going over bumps.
Sunday, January 20th, 2008 AT 11:46 PM
