Ok first we are going to do a self test which is using the cruise to tell us weather or not there is anything wrong with the speed sensor first ok. Now this sequence will need to be kind of quick but you must pay attention to the cruise light as it will flash and give codes to tell us weather or not to do the test on the VSS ok. You will be pressing the buttons on the steering wheel for the cruise so it will talk to us ok.
1) Put in park and set E-brake, while holding the off button turn the key on engine off. The cruise light should have flashed once to tell us it in self diagnostic mode. If it didn't flash then repeat this step.
2)release the off button within 5 sec of turning on the key and now press the on button. Now press the remaining speed control button's in the following sequence ok - ON, RES, COAST, SET/ACCEL. As each button is pressed the cruise light will flash, wait till the light goes out to press the next button.
3)After completed the cruise light will flash to indicate pass or fail. Count the flashes.
4) Now the actuator will perform a test and lift the throttle 1 to 10 mm after throttle has returned the turn off key.
Get back to me after this with how many flashed you counted and we will go to the next step.
Feb 2, 2009 at 5:40 AM
