when in auto drive the car shift into low range 4 wheel drive and the overdrive light starts to flashing and want change gears. You can shift the 4 wheel drive back to auto, but the gears still stays into low range four wheel drive.
Could this be an electrical problem inside the transmisson or transfer case. I have had the transmisson rebuild about 12 months ago.
Feb 17, 2010 at 7:51 AM
