1998 Ford Explorer rough idle, stalls
HJENKINS73
Engine Performance problem
1998 Ford Explorer 6 cyl Two Wheel Drive 160000 miles
I ha ve changed plugs, wires, oxygen sensor, my truck idles relally rough and has no power in gear, engine runs for a while then stalls out. I had the aame problem before I changed the engine but just intermittly then it would run fine. Only the motor was swapped no other parts except those mentioned above
Aug 2, 2010 at 4:02 AM
MERLIN2021
  • 17,250 POSTS
Any codes? Scan it and post codes and any freeze frame data. Please.
Aug 2, 2010 at 7:06 AM
