1998 Ford Explorer Resetting rear caliper
77,000 MILES • V8 • 2WD • AUTOMATIC
PICSHOOTER
I'm getting ready to replace the rear brake pads. Is the rear caliper reset by pushing in or is a special tool needed to screw it back in
Jul 30, 2008 at 11:57 AM
MUSTANG87
  • 261 POSTS
push in.remove the brake fluid master cylinder cap before you push it back in.if any fluid leaks just add as needed.i use a c clamp for pushing it back in.i just put a piece of wood or anything strong on piston then c clamp it back in.good luck
Jul 30, 2008 at 1:44 PM
