1998 Ford Explorer Replacing burned out CEL
204,000 MILES • 6 CYL • 4WD • AUTOMATIC
CABY
I have passed my emissions inspection completely after replacing an ERG valve... all codes are clear. The only reason I failed... my CEL light won't come on... it must be either burned out, or a wire broken or disconnected. How do I get at it to fix or replace... it seems like I'll have to disassemble half the car to get at it!!!! HELP!!!
Aug 30, 2010 at 11:21 PM
WRENCHTECH
  • 20,758 POSTS
You do have to remove the cluster but it's not all that hard. There will be a bezel in front of it to come off first and then the cluster should be able to be removed. You will have to unplug it when half way out.
Aug 31, 2010 at 12:07 AM
