1998 Ford Explorer raogh idle
94,000 MILES • 4 CYL • 4WD • AUTOMATIC
MUSTANG502
my exploer is idling rough at cold and warm temps, i have changed the coil, wires and plugs. i tested the fuel pressure and it is at 33 psi at idle. i have run out of ideas as to what might be wrong. also the engine light is not on
Mar 22, 2010 at 2:52 AM
  • 110,251 POSTS
Have you checked for vacuum leaks?
Mar 22, 2010 at 3:45 AM
MUSTANG502
yes i have checked for vacuum leaks......i checked the timing and it seems as tho it is running at about 20 degrees....i was told that the timing is controlled by the computer and i will need to replace that...is that so?
Mar 22, 2010 at 3:55 AM
  • 110,251 POSTS
The timing is run by the computer, but it is based on signals from other components such as a crank sensor, throttle position sensor... Has anything other been checked? And when you say 20 degrees, is that BTDC or ATDC
Mar 22, 2010 at 6:18 AM
MUSTANG502
that is btdc and i have replaced the crank position sensor and still runs rough, replaced all oxygen sensors and still runs rough.
Mar 22, 2010 at 6:46 AM
  • 110,251 POSTS
THe only thing I can think of is you've missed a vacuum leak or have a weak cylender (lower compression), but that is unlikely with only 94K on it.
Mar 22, 2010 at 3:19 PM
