1998 Ford Explorer power windows do not operate
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
RNIXON
my power windows stopped working and unable to use using the switch at the drivers door or any other door. the moon roof will work.
Feb 25, 2010 at 6:41 AM
  • 110,251 POSTS
Are you getting power to the switch on the driver's door?
Feb 26, 2010 at 6:20 AM
RNIXON
The door look button is the only switch that works. The unlock does not, nor do the 4 window switches work
Feb 26, 2010 at 6:24 AM
  • 110,251 POSTS
To the best of my knowledge, the main switch on the driver's door provides power to the other switches. That is why I questioned if it was getting power.
Feb 26, 2010 at 7:11 AM
