1998 Ford Explorer power windows
1998 FORD EXPLORER
206,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALLYANDLYNN
My power windows dont always work. Power them down and wont be able to power back up. Seems to be worse in warm weather. I have trie another switch, same thing happens. This is the main switch for the truck, controls everything in the truck, from the drivers door. Is my problem the relay or maybe a short somewhere. Thanks
Apr 18, 2009 at 2:42 PM
  • 110,236 POSTS
I would remove the door panel when it isn't working to check to see if there is power to the motor. If there is, chances are the motor is going bad.
Apr 19, 2009 at 9:35 AM
