1998 Ford Explorer Possible vacuum leak
WWJD10334
Engine Performance problem
1998 Ford Explorer 4 cyl Automatic 115000 miles
in the winter my car will start up but the engine dies, all the electrical things still work. It is not the battery because it has been changed and it is still doing the same thing. There is a clicking noise while and after the engine runs. when sitting stil the rpms stay between 0 and 1. In the winter when it first starts the rpms jump to above 2 and will either move up and down between .5 and 2.5 or just go to 0 and shut off the engine. I was told it was some kind of vacuum leak.
Aug 27, 2009 at 1:19 PM
  • 75,988 POSTS
Thank you for the donation it helps runs the site
Do you have a check engine light and when was the last tune-up??
Lets try cleaning out the idle air control valve and test the throttle position sensor then report back.
Aug 27, 2009 at 1:27 PM
