1998 Ford Explorer PLEASE HELP
LISAMM26
1998 Ford Explorer
i need to know the engine size and the ratio. my rear went and i want t replace the entire rear so i need to ratio and engine size to find a rear at junk yards
Aug 23, 2010 at 1:31 PM
  • 110,248 POSTS
The only way to tell is by counting the number of turns the pinion gear makes compared to the axle. As far as the engine size, it should be listed under the hood on one of the factory lables. It is either a 3.0L or a 4.0L.
NOTE: If you call a dealer with the VIN number, they may be able to tell you what differential you have.
Let me know what you find.
Aug 23, 2010 at 3:35 PM
