1998 Ford Explorer outside drivers side door handle
JIMBO2007
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic
the door handel rod has fallen off do i have to remove the handel from the outside to put the rod back on and how?
Jun 2, 2008 at 6:58 AM
AMANDA38B
I dealt with this about a year ago. You will need to remove the interior door panel. Be careful with the electrical wiring and disconnect properly to avoid further problems. Once you have a clear view of the compononents it's easy to see where the problem lies. You can either hook the rod back up or go to Discount Auto Parts and spend a few bucks on a new rod.
Jun 14, 2008 at 4:27 AM
