1998 Ford Explorer Oil filter is stuck
170,000 MILES • V8 • 2WD • AUTOMATIC
NICOLE21
I destroyed the oil filter trying to get if off and now with a wrench i still cant get enough room to get it off how can I remove the oil filter now???
Feb 17, 2010 at 8:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if all else fails drive a screw driver through the side of the oil filter, use both ends of the driver as leverage to twist the filter off. works everytime ;) i find the filters with that black rough stuff at the end (FRAM brands) to be the easiest to work with, maybe a buck or two more but well worth it if your a do-it-yourselfer.
Feb 17, 2010 at 2:42 PM
