Hi there,
I would be checking the oil pump drive, pressure relief valve and oil pick up pipe, Try and get a pressure reading from a master gauge, this will give a better indication as to what is happening, if there is any oil pressure the pump is working, so it could be the valve or a cracked pick up pipe causing lack of supply, you will need to do some more diagnostics first. Hopefully driving has not caused serious damage yet, but if you do drive it with low or no oil pressure you will damage the engine.
Mark(mhpautos0
SPONSORED LINKS
Tuesday, January 8th, 2008 AT 7:42 PM
