I have no regular brake lights but the third brake light (LED) works fine
DASTINE
  • 1998 FORD EXPLORER
  • V8
  • AWD
  • 115,000 MILES
Having a problem with the brake lights on my Explorer. I have no regular brake lights when the pedal is pressed, but the third brake light (LED) works fine. The weird part is that even when the brake pedal is not pressed the third brake light continually flashes at a very high rate, almost like a strobe. As a sided note I also noticed that the door locks stopped auto locking when you put the vehicle in gear at about, or the exact same time the brake light problem started.
What I have tried so far:
1 Checked bulbs and fuses
2. Checked brake light switch (LED third brake light still flash even when brake switch is disconnected)
3. Checked turn signal switch (LED third brake light still flashes when disconnected completely)
4. Checked wiring in steering column and under dash and could find no visible shorts or damage to wiring.
Any ideas? I don't know what to look at next.
Thanks!
Sunday, August 24th, 2008 AT 1:43 PM
BMRFIXIT
  • 19,053 POSTS
Most common is the combination switch on the steering column
This guide can help
https://www.2carpros.com/articles/brake-lights-not-working
put 4 way hazards on off on and then check if they work
Monday, May 10th, 2021 AT 1:44 PM
DASTINE
Thanks, but no good. No matter what I do with the emergencies. As mentioned, the third brake light continues to flash even when I completely disconnect all the wiring from the turn signal switch.
Thanks again for your help.
BMRFIXIT
  • 19,053 POSTS
3RD brake light u said its working
and again combo switch has no control over the 3rd brake light
but the power to the side brake lights run through the multifunction switch
very very common for the switch to go bad
good luck
MOEVINGER
I have exactily this same issue. I have a 1998 Explorer, AWD, about the same milage and the problem is the same.
Did anyone come up with a fix for this?
BMRFIXIT
  • 19,053 POSTS
If signals are working and 3rd brake light is working
multifunction switch no good
have it checked
SKIPPERDAN
  • 6 POSTS
Has anyone come up with a solution to this problem. I have a 98 Ford Explorer with the same problem. I've checked all the wiring, it's ok. The only thing I haven't done is check out the multifunction switch. I do have a book that shows how to do that so that will be my next step. Any input or info would be greatly appreciated. Thanks SkipperDan
SKIPPERDAN
  • 6 POSTS
I checked out the multifunction switch and it is ok. I did find on my stop light switch that has five wires in the plug that two of wires on the plug are hot. I don't believe that this is incorrect. Any input would be greatly appreciated. Thanks
BMRFIXIT
  • 19,053 POSTS
Step on the brakes does the 3rd light work
BMRFIXIT
  • 19,053 POSTS
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_503.jpg
SKIPPERDAN
  • 6 POSTS
Yes, third light does comes on when brakes are applied. The strange part is when everything is off the top mounted third brake light flickers light a strobe light! What's up with that? SkipperDan
BMRFIXIT
  • 19,053 POSTS
Have a helper watch the lights for you as you go under the steering by the brake, twist and move the brake light switch looking for a short
also hold the switch
trying to make the flickering stop
and if it does try to get it going again finding the reason
hope I m not confusing you
also does the 4 way flasher work?
Push the 4 way and step on the brakes does that make any difference
also one more question
how did you determine that the multifunction switch is good?
SKIPPERDAN
  • 6 POSTS
Praise God I found the problem! :-) I removed the top mounted brake light and found a faulty connection which stopped the strobe light effect. Note: The top mounted brake light still was on very dim but not strobing. Then I rechecked the left stop light socket and found that the female prongs were not really that clean so I cleaned them up and also did the right side. I also installed new bulbs, fiqured I might as well as I was in there. And all is great and back to normal. I have brake lights. So, if any one else is having this problem I strongly suggest to start with the fuses and then go directly to the brake bulbs and sockets before thinking it is in the multifunction switch! And running all those test. Thanks for all the input and suggestions! SkipperDan is ready to take on another task! :-)
OUT OF THE BOX
  • 7 POSTS
Update on intermittent brake lights on my 98 explorer:
I thought the problem was solved by cleaning the wiring harness contacts & the brake light switch's matching contacts, but a few weeks later, the same problem returned, intermittent brake lights. What I found was that if the switch was angled to the right or left from parallel with the brake pedal, the brake lights would fail.
I found this video on u-tube that was very helpful, which could be very helpful if you have this problem & just want to get somewhere like home or an auto parts store without taking the chance getting rear ended.
"how to fix a bad brake light switch, not replace"
u-tube member > thomas brian
https://youtu.be/PX6ifXBgX5s
So I removed the brake light switch with just a pair of needle nose pliers & opened it up and found the the internal contacts on pin #1 & 2 were so badly pitted that there was very little of the contacts left. I decided to try filing them with a nail file so if that worked, I could safely drive to auto-zone to get a new one. Filling the contacts did work but, but I don't trust them, so in went the new switch & with the help of my wife, we verified many times that the brake lights came on every time the pedal was pressed and the switch wiggled & giggled.
Be sure to re-secure the wiring harness to the brake light switch.
Even though the B.switch is now new, I still check them every time I leave the driveway.
NOTE: My suggestion to anyone whose vehicle has a lot of miles or if it's been subjected to a lot of stop & go freeway traffic for years, It's a real good idea to check the contacts inside the brake light switch for excessive pitting & replace or repair if necessary.
I'm going to add to the dash an LED/ ect idiot light
to let me know when driving that the brake lights are getting power when braking. To do so, just connect an additional wire to the wiring harness wire that connects with contact #1 (closest to the firewall) that is the positive output to the brake lights, and of course connect a ground wire to your lamp of choice. Note: LED's require a current limiting resistor unless they are rated for 12 volts DC. This way I can monitor brake lights will know (IF) the brake lights are getting power continuously when braking and my passenger will know when I am braking, especially when on the wonderful calif. freeways.
Best of success.
