Having a problem with the brake lights on my Explorer. I have no regular brake lights when the pedal is pressed, but the third brake light (LED) works fine. The weird part is that even when the brake pedal is not pressed the third brake light continually flashes at a very high rate, almost like a strobe. As a sided note I also noticed that the door locks stopped auto locking when you put the vehicle in gear at about, or the exact same time the brake light problem started.
What I have tried so far:
1 Checked bulbs and fuses
2. Checked brake light switch (LED third brake light still flash even when brake switch is disconnected)
3. Checked turn signal switch (LED third brake light still flashes when disconnected completely)
4. Checked wiring in steering column and under dash and could find no visible shorts or damage to wiring.
Any ideas? I don't know what to look at next.
Thanks!!
Thanks!!
Aug 24, 2008 at 6:43 AM
