I just purchased this vehicle with 66,500 miles on it. I hired a lemon detector company to check it out for me and they found no issues at all (except the need to break pads and tired withing the next 5000 miles or so). This vehichle seems super clean. i have dealer service records up to 2006. one owner.
They recommended an oil/filter change and transmission oil/filter change.
I took it to a lube joint who changed the oil/filter and flushed the engine. They told me they could not change the transmission fluid as it sat behind the muffler. is this the case? Also, do i NEED to change the transmission fluid? How can I tell if it needs changing and do I need to have it dealer serviced or will local mechanic do?
thanks!
thanks!
Jul 14, 2008 at 6:01 AM
