1998 Ford Explorer Liftgate lock
185,000 MILES • 6 CYL • 4WD • AUTOMATIC
PHILIPR
I recently replaced the lock activator for the liftgate on my Explorer. It works in sync with the other 4 doors. The problem is this - the window lock on the liftgate does not lock with the rest of the locks. It is opposite of the rest. When I lock the vehicle the pushbutton is unlocked and you can open the window (the window lifts up). I have disconnected the electric to the actuator and keyed the pushbutton to the opposite position to no avail.
Mar 24, 2009 at 4:57 AM
IMPALASS
  • 3,112 POSTS
Hello –
As I review different areas about this system it does keep asking to check the DTC for codes.
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Mar 24, 2009 at 10:08 AM
IMPALASS
  • 3,112 POSTS
Hello - By the way, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recalls_15.jpg
Mar 24, 2009 at 2:19 PM
PHILIPR
Okay I went to AZ to get codes. Got codes, all for Check Engine light issue. None for liftgate issue. Where to next? I had the recall issues fixed the other day.
Mar 26, 2009 at 6:30 AM
IMPALASS
  • 3,112 POSTS
Hello - Thanks for getting back with me. Sorry for the delay in getting back with you..........I encountered some technical difficulties........... You problem is not on the troubleshooting chart so we are going to have to guess through this. Can you turn the electrical connector around and connect the other way? Reason, to test the lock motor you can apply 12v and ground to the elec connectors and the lock should operate in one direction. Then, reverse the 12v and ground on the connector and the lock will reverse. Can you try that please. Now there is a note on the lift gate window for removal and installation of the lift gate lock. I have attached for your review to see if you missed a step. Removal & Installation (Liftgate Lock) 1. Open liftgate window glass. Remove liftgate inside handle screws. Remove liftgate trim panel from around door lock knob. Remove screw from opening. Using a molding/trim removal tool, carefully pry on liftgate door trim to disengage clips. Remove liftgate window latch door trim panel. 2. Remove watershield from door. Disconnect liftgate latch actuating rod by opening clip and removing rod from clip. Mark position of the liftgate window latch before removing. Disconnect electrical connectors and remove nuts securing latch to door. Remove latch. (Note the step above to Mark position of the liftgate window latch before removing.) 3. Remove push-pins and remove vent panel. Disconnect liftgate latch release actuating rods by opening clips and removing rods from clips. Disconnect liftgate handle and lock cylinder rods by opening clips and removing rods from clips. See Fig. 4 .
https://images.2carpros.com/forum/automotive_pictures/248015_Fig_4_2.jpg
4. Remove liftgate latch remote control bolt. See Fig. 5 . Disconnect liftgate lock actuator connector. Remove bolts securing liftgate actuator to door and move actuator to left side access hole to remove. To install, reverse removal procedure.
https://images.2carpros.com/forum/automotive_pictures/248015_Fig_5_1.jpg
NOTE: Manually close liftgate window latch and install control rod. Make sure the bell crank of the liftgate latch remote control is in the unlocked position to adjust control rod properly. When reinstalling all control rods, they should be set in a relaxed position and not binding for proper operation.
Mar 27, 2009 at 2:13 PM
