1998 Ford Explorer leaking oil
ANNAMARIE30
  • 1998 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 123,786 MILES
My car is leaking oil from the engine and it is shaking very badly. I am wondering what could be the issue and if I can get an estimate or guess as to what it will cost to fix
Saturday, October 10th, 2009 AT 8:30 AM
CARLIFE65
  • 200 POSTS
If you engine is leaking oil, is it from the side, or under the engine? If it from the side, inspact you valve cover gasket. If its under, it would be your oil pan gasket, now the shaking that its doing, is it front, or back, anyway inspact your front wheel hub bearing, it could be dry orworn, the same for the rear, look at your wheel bearing, some shop start at 75.00hr and up that about a 3 to 4 hour job, get back to me and let me no.
Saturday, October 10th, 2009 AT 10:50 PM
