When I lived in Denver my 98 Explorer sometimes would not start on (what seemed to be) cold mornings. I would have to give it gas (instead of the fuel injection working) and it would then run fine. After I drove it for awhile it ran great. Over the winter I left it at mechanic's overnight where he had no problem starting it at all. We chalked it up to bad gas or the cold, etc. When I moved to Texas the problem became more persistent and happend more frequently. I dumped fuel injection cleaner into it and that would seem to clear it up, but now that doesn't even work anymore. Replaced one of the oxygen sensors & that temporarilly worked. Had the fuel filter replaced where it ran good, then back to same issues. At this point, it won't start without me giving it gas and it won't idle. I have to keep my foot on the gasj at all times or it will stall out. I'm pretty good at braking with my left foot. I cleaned out the IAC and that did nothing. In my garage, from the drivers seat with the door open, I can hear a hissing so I wonder if it could be a vacuum hose. Also, something interesting I've noticed, is that it makes a sound that is in a pattern. When its running it makes clicking noises that happen about every 15 sec in a pattern. I've also noticed that my two-footin' it is hard on the transmission. Any ideas?
Mar 6, 2010 at 8:10 AM
