Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Stall at Idle
1998 Ford Explorer Idleling
1998 FORD EXPLORER
103,098 MILES • 6 CYL • 4WD • AUTOMATIC
TANNA AND BUCK
MEMBER
1 POST
will run but won`t idle
Nov 22, 2009 at 11:33 AM
Experienced Mechanic
Clean out the idle air control valve , EGR and PCV valves and test the TPS/MAF/MAP sensors to include a fuel pressure check
Nov 22, 2009 at 11:55 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
