1998 Ford Explorer Fuel Pump question
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENTGADAMS
Just had a problem with the Explorer starting after a short 10 mile run! Took 3-5 times to start, then started! Made another run and had the identical problem but this time it took 30 minutes to get it restarted!
Feb 2, 2009 at 3:08 AM
  • 110,248 POSTS
Hi:
It could be a fuel pump problem. You need to check pressure. Watch this video. It will explain how to check pressure. Also, most nationally recognized parts stores will lend or rent the pressure gauge to you.
Go to this page:
http://www.2carpros.com/dia/test_fuel_pressure.htm
If this doesn't help, let me know and I'll talk you through other options.
Feb 3, 2009 at 12:44 PM
