1998 Ford Explorer Fuel Pump Fuse
184,000 MILES • 6 CYL • 4WD • AUTOMATIC
FASTBACKCHEVY
1998 fuel pump changed pump checkd all relays replaced them all... Still having the fuse pop everytime i turn key on.. Im lost at this.... I have power to the intertia switch and power under the hood for the fuse and the relay all connections look very good i have power to the intertia switch when the key is engaged... then the fuse in the engine compartment blows everytime old pump was bad and the new one was tested before i put it in the tank.... Any suggestions i have checked wiring top to bottom... any feedback would be of much help...
Feb 13, 2010 at 10:08 AM
  • 110,248 POSTS
Have you checked the wiring from the relay to the tank for damage? Many times they will get pinched and cause the fuse to blow.
Feb 14, 2010 at 6:30 AM
FASTBACKCHEVY
I sure have all seems well
Feb 14, 2010 at 7:55 AM
