1998 Ford Explorer Front Sway Bar Links
MIKEKON5
  • 1998 FORD EXPLORER
Suspension problem
1998 Ford Explorer 4 cyl Four Wheel Drive Automatic
How tight are the nuts suppose to be on the sway bar links?
Sunday, July 25th, 2010 AT 4:08 PM
  • 110,182 POSTS
Hi:
Tighten the mounting bracket bolts to 65-91 ft. Lbs. (88-119 Nm). The end link assembly must be tightened with the vehicle weight on the front wheels. Lower the vehicle then tighten the end link retaining nut to 10-13 ft. Lbs. (13-17 Nm).
Monday, July 26th, 2010 AT 12:57 AM
