1998 Ford Explorer Front End
150,000 MILES • V8 • AWD • AUTOMATIC
JMALEAR1
What type of fluid does my front end take? It's making a roaring sound after it warms up and i have replace the fluid with gear oil, is this the right fluid for it???
Jan 15, 2009 at 5:34 AM
  • 110,248 POSTS
Hi:
Yes, the front differential takes gear lube, GL5. Has the noise gone away?
Jan 16, 2009 at 5:10 AM
JMALEAR1
No, actually the noise has gotten worse since I added gear oil.
Jan 16, 2009 at 12:06 PM
  • 110,248 POSTS
Hi:
As a result of being low on fluid, it sounds like a bearing has gone bad. Check the front drive shaft where it attaches to the differential and shake it to see if there is play.
Jan 16, 2009 at 2:14 PM
