How do I change the flasher fuse
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
MDHUNT
How do I change the flasher fuse. It states it is under the steering column but I can not find it. I have had three people try to find where we change the fuse.
Jul 20, 2009 at 2:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle's turn signal and hazard flasher relay is indeed in the steering column. However, it is NOT a fuse, it is a relay. It should be a black or grey square with prongs coming out of the end.
May 10, 2021 at 6:51 AM
SQM
  • 6,383 POSTS
The flasher relay is located under the steering column. I have attached diagrams shows the location. Also included a picture of what the relay looks like.
https://www.2carpros.com/articles/turn-signals-not-working-blinker
Oct 28, 2021 at 12:50 PM
