1998 Ford Explorer error codes
129,789 MILES • 6 CYL • 2WD • AUTOMATIC
DBANKBROKE
i had explorer inspected and failed bgecause of 2 error codes
1. P0156 02 SENSOR CIRCUIT MALFUNCTION (BANK 2 SENSOR 2)
2. P0161 02 SENSOR HEATER CIRCUIT (BANK 2 SENSOR 2)
I HAVE REPLACED ALL 3 SENSORS ON CAR BUT CHECK ENGINE LIGHT KEEP COMMING ON.
IS THERE A SLOUTION ?
Nov 11, 2008 at 5:03 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:bc170f227f="dbankbroke"]Computer problem
1998 Ford Explorer 6 cyl Two Wheel Drive Automatic 129789 miles
IS THERE A SLOUTION ?[/quote:bc170f227f]
Have you had the code erased. If you haven't then the codes will take 50+ key starts to clear. If you did have codes cleared are they the same codes coming up.
If they are then check for damaged wires and/or connector. Check for exhaust leak.
Nov 11, 2008 at 6:21 AM
