I am experiencing an issue where while under normal driving conditions the engine makes a high revving sound while the tachometer indicates that the RPMs are dropping. The RPMs are most certainly increasing at this time. When I push the accelerator pedal the issue will correct but then recur a short time thereafter. This issue has occured in all forward gears and in neutral. Since this issue occurs while the engine is in neutral I do not believe it to be a transmission issue. Can anyone offer any places to look?
I have tried to get a circuit diagram of the tach circuit but there is no individual tach circuit, it appears that the tach signal is generated by the Crankshaft Position Sensor.
Thanks in advance for any assistance.
Jon P.
Jon P.
Jun 26, 2009 at 9:53 PM
