1998 Ford Explorer Engine Misfire
92,000 MILES • 6 CYL • AWD • AUTOMATIC
HARRY178
My sports Ford Explorer 1998 model was having problem during the cold start with rpm going down from normal 500 to 400 or 300 and sometimes even the engine foes off. Got it checked from a expert and he handed me a $600 estimate for the job and told me to get get the spark plugs and the wire sets with Bosch platinum sparks plugs but the problem is still like that and now it had started misfiring even while running after fully warmed up engine. Please give me suggestion on what to do.[img:993edb128e]http://www.2carpros.com/forum/automotive_pictures/332174_i1_1.jpg[/img:993edb128e]
Mar 15, 2009 at 5:56 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Mar 15, 2009 at 6:36 PM
