1998 Ford Explorer Engine drive chain
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
GCA1265
Recently the engine started making a loud noise and began to sound like a diesel. I thought I had rod problems and took it to a Ford dealer. They said that the engine drive chain needed to be replaced but they would not repair it due to the high mileage and they wanted $8,000 to install a new engine. We like the car and would like to keep it. We live in San Diego ... can this repair be made and how much should it cost? Any recommendations on where to have it repaired? Thanks.
Aug 27, 2008 at 1:14 AM
OBXAUTOMEDIC
  • 3,713 POSTS
[quote:8e32d1f4f9="gca1265"]Engine Mechanical problem
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic 160000 miles
Recently the engine started making a loud noise and began to sound like a diesel. I thought I had rod problems and took it to a Ford dealer. They said that the engine drive chain needed to be replaced but they would not repair it due to the high mileage and they wanted $8,000 to install a new engine. We like the car and would like to keep it. We live in San Diego ... can this repair be made and how much should it cost? Any recommendations on where to have it repaired? Thanks.[/quote:8e32d1f4f9]
I believe they are talking about the Timing Chain and yes the repair can be made. The cost of the repair will depend on the engine if it is a 4.0L 6 cylinder Over Head Valve (ohv) Push Rod Engine or a 4.0L 6 cylinder Single Over Head Cam (SOHC).
The repair can be done at your local garage. I would call around for pricing and find a good reputable one.
Aug 27, 2008 at 4:28 AM
GCA1265
The engine is a 4.0L 6 cylinder Single Over Head Cam (SOHC). Can you give me the estimated cost based on the model engine repair manual that insurance companies and estimaters use? Thanks.
Aug 27, 2008 at 3:07 PM
  • 75,988 POSTS
Labor rate varies with location could range from $70-$130.00 per hr. shop around
https://images.2carpros.com/forum/automotive_pictures/12900_timing_chain_1.jpg
Aug 28, 2008 at 1:54 PM
BADBO
  • 35 POSTS
14.5 hours at what ever rate you have near you. 4.0 sohc has a front and rear timing chain. Drive to Texas and I will do it for 5000. Just kidding. Hope this helps.
badbo
Aug 28, 2008 at 2:14 PM
OBXAUTOMEDIC
  • 3,713 POSTS
Thanks rasmataz and badbo for helping out here I have been very sick last few day. Finally feeling better.
Thanks Again
Aug 30, 2008 at 1:24 PM
