1998 Ford Explorer DTC Codes
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
MMILLER1994
I purchased a OBD2 device where I can hook up to my car and detect any problems (DTC's) with my car. When I did, I came up with one code, a P1762. This states I have an "overdrive band failed off" error. When I took it to the shop to get fixed they state there are 2 other codes that showed up. P7035 & P7032. I have tried to locate these codes in my manual of the OBD2 device as well as on the internet. I can not locate them. Can anyone explain what these codes mean?
THanks. Mike
Mar 22, 2008 at 2:37 AM
MERLIN2021
  • 17,250 POSTS
I would say the other 2 codes are P0732 and P0735, numbers do not run int 7000's!
732= gear 2 inncorrect ratio, and 735=gear 5 inncorrect ratio...all tranny related.
Mar 22, 2008 at 4:02 AM
