Remove window crank if manual.
Then remove the screws from the panel. And using the trim tool or a large scredriver slowly pry out the pins that hold it on to the door.
Try doing it in warm heated area that way the plastic isnt brittle and breaks.
SPONSORED LINKS
Wednesday, February 25th, 2009 AT 7:44 PM
