1998 Ford Explorer consel warnings
116,546 MILES • 6 CYL • 4WD • AUTOMATIC
W FELIX
Low washer fluid warning comes on each time I start engine
Nov 27, 2009 at 7:06 AM
RICKMAR
  • 170 POSTS
That is just indicating to you your washer fluid reservoir is empty or low. It is located on the passengers side of the vehicle in the engine compartment. There are 2 reservoirs windshield washer fluid and engine coolant the one closest to the fire wall is for the windshield washer fluid.
If there is plenty of fluid present in the reservoir the sensor inside the reservoir located near the bottom needs replacement. Replacement of the sensor would require removal of the washer reservoir to gain easy access for removal and replacement.
Rick
Nov 27, 2009 at 1:15 PM
