Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Stall While Driving
1998 Ford Explorer cold engine will not stay running.
1998 FORD EXPLORER
19,100 MILES • 6 CYL • 2WD • AUTOMATIC
RAY BAILEY
MEMBER
1 POST
If temp. is below fifty, I have to pat the accelarator for 2-3 minutes before the motor will run on its own.
Feb 13, 2010 at 9:49 PM
Experienced Mechanic
HAs the check engine light come on? Have you checked for vacuum leaks and fuel pressure?
Feb 14, 2010 at 6:16 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
