1998 Ford Explorer cold engine will not stay running.
19,100 MILES • 6 CYL • 2WD • AUTOMATIC
RAY BAILEY
If temp. is below fifty, I have to pat the accelarator for 2-3 minutes before the motor will run on its own.
Feb 13, 2010 at 9:49 PM
  • 110,251 POSTS
HAs the check engine light come on? Have you checked for vacuum leaks and fuel pressure?
Feb 14, 2010 at 6:16 AM
