1998 Ford Explorer Check Engine Light & Steering
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
AUTUMROSE
I went to a mechanic to get my inspection renewed and I failed (which I knew I would) for more reasons then I had anticipated. The check engine light was on so they ran the simple test to get the codes which came back as P0171 or P0174. I declined the total diagnostic because their price was around $100 and I wanted to wait and find out more info first. They also failed my car saying that I needed ball joints replaced and wheel bearing repack.
Honestly I know very little about these kinds of things and don't want to get over charged.
What do you think I should do and how much will all this cost me?
Unfortunately I don't have the ability to do any repairs on my own, I googled for the how-to videos and its way out of my league!
I'd appreciate any insight you could provide, I hate when mechanics try to take advantage of people like me who have little car knowledge.
Thanks.
Apr 19, 2009 at 1:01 PM
BMRFIXIT
  • 19,053 POSTS
The two codes provided its an indication and most common is a vacuum leak
have to check vacuum lines
smoke test needed to check for the leak if visual check did not come with a result
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 19, 2009 at 1:10 PM
