Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Warning Lights
Check Engine Light
1998 Ford Explorer check engine light
1998 FORD EXPLORER
12,100 MILES • V8 • AWD • AUTOMATIC
SUPERVISOR7210
MEMBER
failed inspection because check engine does not come on when you turn the ignition on
Jan 7, 2008 at 4:28 AM
2CARPRO JACK
Experienced Mechanic
Need to remove cluster and check/change bulb to start
Jan 7, 2008 at 6:35 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
