1998 Ford Explorer Car won't start
JHENN
  • 1998 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 115,000 MILES
Car will not start. It turns over, starter was good and battery was good. All lights and other come on. Could it be a fuel pressure issue? Not sure but can't get it started.
Tuesday, June 24th, 2008 AT 12:31 PM
BMRFIXIT
  • 19,053 POSTS
I would check for spark and also check fuel pressure
most likely fuel pump but you need to check 1st
Risk of fire.
"Â Keep cigarettes, sparks, open flame, and other
sources of ignition away from vehicle.
"Â Gasoline, methanol, and oxygenated fuels are toxic
and flammable and must be handled appropriately
Wednesday, June 25th, 2008 AT 8:33 PM
JHENN
It was the crank shaft sensor
Monday, June 30th, 2008 AT 12:16 PM
