It starts up then the rpm's comes down like it thinks it's already warmed up. You have to manually work the gas until it warms up, then it runs fine.
I have already replaced the idle control valve.
I run fuel system cleaner through it and have a K & N air filter.
I have thouroughly cleaned the filter and intake.
I have replaced the temp sensor to the computer,
I had a code for bank 2 oxygen sensor and replaced it.
Oct 13, 2008 at 12:44 AM
