Brakes problem
1998 Ford Explorer 4 cyl Four Wheel Drive Automatic
the piston in the front passenger caliper broke and broke the rotor, i replaced 3 calipers all 4 rotors and then bled the breaks, pedal was very spongey. so i replaced the vac booster and master cylinder, bled the brakes again and while the truck is off theres pressure inb the pedal but as soon as i start it the pedal goes to the floor again..im at a loss what else can i do? i tried putting the key to on and pushing the pedal then releasing it to reset the brakes but it did nothing
Feb 16, 2010 at 11:40 PM
