1998 Ford Explorer Brake light issue
68,000 MILES • 6 CYL • 4WD • AUTOMATIC
PETERON
I have an issue with my brake lights. My brakes work fine, the truck stops on a dime if I have to but I have to put my brake pedal as far to the floor as it will go for my brake lights to come on. Anyone have idea as to why this might be happening?
Oct 13, 2009 at 4:48 AM
MIKE H R
  • 3,094 POSTS
What it sounds like the stoplight switch is going bad. Have checked to find out if adjustable, but found no reference to adjusting. The switch is located on the upper part of the brake pedal arm and connects the switch to the brake push rod..
Oct 13, 2009 at 8:53 AM
PETERON
Thanks for the response, I will take your advice!
Oct 13, 2009 at 11:43 AM
