Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Brakes
Bleed - Flush
1998 Ford Explorer Bleeding brakes
1998 FORD EXPLORER
116,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRNMTNGIRL
MEMBER
1 POST
What is the correct order for bleeding the brakes on a 98 ford explorer?
Sep 8, 2008 at 10:06 AM
BLACKOP555
Experienced Mechanic
rght rear, left rear, right front, left front. if that oesnt help then see if the master cylinder can be bleed or the combo valve.
Sep 8, 2008 at 11:41 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
