1998 Ford Explorer Battery Cables
JDG527
Electrical problem
1998 Ford Explorer Two Wheel Drive Automatic
How do I replace the battery cables on a 1998 Ford Explorer?
Jul 21, 2008 at 10:35 AM
MERLIN2021
  • 17,250 POSTS
Trick question? REMOVE THE NEGATIVE CABLE FIRST WITH a 10mm wrench, follow the cable to the block and remove the end. Then remove the positive. Put the new positve on and then the negative last!
Jul 21, 2008 at 11:18 AM
