1998 Ford Explorer alternator
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
KSCOVILLE
Do I have to remove the radiator hose to change the alternator?
Jan 16, 2010 at 7:44 AM
  • 75,988 POSTS
REMOVAL
Disconnect the battery ground cable.
Remove the air cleaner outlet tube.
Remove the drive belt.
Disconnect the wiring harness to voltage regulator electrical connector.
Remove the B+ terminal cover.
Remove the B+ terminal electrical connector.
Remove the B+ terminal nut.
Disconnect the B+ terminal electrical connector.
Remove the wiring harness-to-generator pushpin.
Remove the Generator (GEN) .
Remove the stud bolt.
Remove the bolts.
Remove the generator.
INSTALLATION
Follow removal procedure in reverse order. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Jan 16, 2010 at 7:48 PM
