Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Drivetrain
Transmission
Clutch
Adjust
1998 Ford Explorer Adjusting the Clutch
1998 FORD EXPLORER
172,000 MILES • 6 CYL • 2WD • MANUAL
SANDIENLEON
MEMBER
How do I adjust the clutch on my explorer?
Oct 8, 2009 at 1:39 AM
DOCFIXIT
Experienced Mechanic
Clutch system is hydraulic and self adjusting. What's the problem?
Oct 8, 2009 at 1:55 AM
SANDIENLEON
MEMBER
It is supposed to be automatic, but I dont know how much clutch I have left. How can I determine if there is any adjustment left?
Oct 8, 2009 at 4:42 AM
DOCFIXIT
You can tell by pedal height as to clutch engagement. If right off floor then disc is thin also hard to get into 1st or slipping in high.
Oct 8, 2009 at 4:52 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
