1998 Ford Explorer AC/Heat Control
101,000 MILES • V8 • AWD • AUTOMATIC
BBECKUND
I just acquired a used 98 Eddie Bauer model explorer and the automatic AC/Heat control does not seem to be automatic. Only one temperature setting even though the control (LED) on the front panel says that has been changed. Any ideas on fixes. Second part can a replace with a manual system from an XLT Explorer 97.
Thanks
Mar 7, 2008 at 6:08 AM
BMRFIXIT
  • 19,053 POSTS
do you mean the defrost /panel/ floor
or the temp
if the heat it may need a blend door motor
if the doors check vacuum hoses
Mar 9, 2008 at 5:20 AM
