1998 Ford Explorer 4 wheel drive
10,500 MILES • 6 CYL • 4WD • AUTOMATIC
FIREKNIGHT
i have a ford explorer sport trac. recently it started getting stuck in 4 wheel low. there was a hose in the back that was unconnected so i reattached it but that didn't solve the problem. the hose isn't connected to anything at the other end. flipping the switch from auto to 4 wheel low and back doesn't solve the problem. is there anything else i can do?
Mar 24, 2010 at 7:48 AM
  • 110,251 POSTS
When it doesn't switch, have you checked to see if there is power to the actuator on the transfer case?
Mar 25, 2010 at 3:26 AM
